nope nothing hooks to the battery....unless you bought part c which is the relay harness..which you dont need. you have them hooked up correct in the pics, see the blk & red wired plugs that come out oh the boot with the hid bulb? that connect to the plug the origanally plugged into the oem lights remember the lows will have to switch the wires. each unit is independant from the others so the 2 single plugs out of the ignitors hook up to the 2 single plugs coming out of the other side of the rubber boots
* Last updated by: scottjkyl on 10/24/2009 @ 7:55 PM *
