Thread: removing ecu ?
Created on: 03/26/15 05:31 PM
miket
miket's Gravatar
removing ecu ?
03/26/15 5:31 PM
can I just slide forwardout of rubber harness
do I need to disconnect rubber one one sid or other don't want to rip anything
Need to find license plate light wires to hook up new lockhart plate frame with light
Original rear fender ext gone
09 zx14 2000 miles black new to me
02 zrx 1200 r red way too much invested but I love this Bike!
83 gs 1100 red with es fairing again way too much$$$ Cleanist one I've seen
RE: removing ecu ?
03/26/15 7:05 PM
Steps 13 and 14 here.
You also will see the license plate light wire in step 14. It is the smooth black wire that runs under the ECU snd goes down the hole in the udertail.
I helps to hold the rubber retainer stable with your palms, then push the ECU forward with your fingers from behind. It's just a tight fit. There are no fasteners that need to be removed.
* Last updated by: Rook on 3/26/2015 @ 7:10 PM *
miket
miket's Gravatar
RE: removing ecu ?
03/27/15 8:02 AM
Thank you all your info make life easier for me
RE: removing ecu ?
03/27/15 9:05 AM
Sure. Ask any time.
RE: removing ecu ?
03/27/15 9:24 AM
I always just remove the tool kit box,then grasp the connectors there,and gently wiggle it out while holding the rubber part that goes across the ecu.
toledoUPSguy
toledoUPSguy's Gravatar
RE: removing ecu ?
03/27/15 2:24 PM
I also remove the toolbox and just lift the ecu/relay box off the 2 projections that hold the rubber case.
Rktsled
Rktsled's Gravatar
RE: removing ecu ?
04/01/15 3:57 PM
Remove toolbox and spray a little silicone, slides right out.
Rktsled
RE: removing ecu ?
04/01/15 5:01 PM
SIlicone's the lube for rubber but I recently read that it also causes rubber to swell a tiny bit which makes it an excellent seal for O rings (in certain applications). If the rubber already fits extremely tight DON'T use silicone. I've had a hell of a time getting my steering stem mount out after using silicone a short time earlier. I had to tap it up with a wood dowel inserted from belo the steering stem. The O-rings on the mount already fit so tight, I decided a little lube might help the thing slide out but instead, it got tighter.
* Last updated by: Rook on 4/1/2015 @ 5:01 PM *
Rktsled
Rktsled's Gravatar
RE: removing ecu ?
04/01/15 5:41 PM
Silicone will swell rubber a little, but the ECU holder isn't that tight to begin with, never had any problems.
Rktsled
RE: removing ecu ?
04/01/15 7:36 PM
I'm sure it would be just fine for the ECU boot. The swelling is minuscule. It might even be of benefit if tightens up a hair after the the ECU gets pulled a few times.
