I've missed shifts with the HM at high rpm but I'm pretty sure it was below redline. i have assumed it was mostly due to shifting too slow or not high enough with my foot. To my line of thinking, a slow turning motor is a lot mor forgiving of a lazy shift than a fast turning engine. The kill time is what it is but there's no denying that the teeth of the gears are passing each other up a lot faster at high rpm than low rpm. The 65 mls might not be a large enough window of time to permit the gears to mesh reliably. They kick the shift backward to the previous gear or somehoe stick between gears in false Nuetral. By contrast, I don't ever think I've missed a quichshift at lower rpm. It seems to work easier when the motor is turning slower.
My knowledge of how the gearbox and clutch work is very limited but that's how I envision the squickhift missing phenominon. Using the clutch is much slower. Load is off the engine for 3 or 4 x longer and there is simply more time for things to right themselves if gears don't quit line up. On top that, the clutch allows the gears mesh perfectly in a gradual way. The quickshifter wants the gears engaged right now!
My Gen1 does not have TC or factory presets for TC. I'm not saying that the Gen 2 wich does have TC might not be reacting to the quickshifter as you explained but I'm saying my Gen1 does it too. It's not all the time but if a quickshift is going to miss, it's going to be a high rpm shift. Of cours, if I really have a lazy toe, I guess I could get it to miss shift at any rpm.
I was planning to try GP shift pattern to help eliminate shift missing. I am pretty sure it will improve the situation a lot but it is not something that can be done with the HM lever....unless you can get the HM lever onto a rearset and use a shift rod with heim joints to reverse the shift pattern.
* Last updated by: Rook on 5/31/2015 @ 10:01 PM *
