If you call having to send out your ecu to be flashed every time you want to make changes or adjustments to the launch control, user configurable, then yes it is very much so...having it shipped out for a "one size fits all" launch controller ain't for me...
No, not for me either. Yet there is now one more reason to buy the software. Great tools to fine tune your bike. Go for it.
I was talking with Justin about my current set up awhile back when this came out. What I was hoping to get was a 5 volt signal from ECU for Full Auto shift. For me this would mean the SB6 was no longer needed.
As my bike is now My launch control is set up through the SB6. All my settings are time based per gear, to full power. RPM programed in for full Auto shifting. LOVE it. Yet,,,
I am constantly playing with settings to keep the back tire blowing off. Different traction, hot or cold day etc. Being locked in to one setting for All riders, diff swing arm length makes no sense to me. But for the Novice rider stock bike I'm sure this would be a blast to have fun with.
Justin feelings the same, Response below.
Hi RickWe have some default settings for each model available, but like with anything you will get the best results if things are fine tuned for each bike and rider's preferences. For example, we have found you should adjust the launch RPM based on rider weight, if the rider is heavier then you can set the Launch RPM a little higher. Also once you are chasing 10's in drag racing you would want to fine tune things based on track condition etc. e.g. if the track is sticky you can launch harder with a higher Launch RPM, so having the ability to adjust at the track is a good idea (not essential but a good idea). Also you would want to adjust the Launch Control Ramp based on how quick the bike/rider is.
We are also about to release a couple of additional data log parameters which will help guys to fine tune their drag runs, we currently have TPS, RPM, Gear, AFR available, we recently added Clutch and we are just about to release Rear Wheel Speed, you can log all this data on one of our Log Boxes, then after a run at the track you can open up the log in the Data Viewer and see exactly what happened in the run, you can really improve your times by analyzing the data.
This same data can be used to trim the fuel maps in the AutoTune screen based on your target AFR and the data logged from the prevailing conditions at the track, this ensures the bikes is tuned correctly based on the current conditions.
There should be a good amount of interest for these features as we have been asked about them quite a bit, should help guys to get their bikes off the line faster and improve times at the track :)
The ECU controlled quickshifter with fuel and ignition cut works really well.
Here is an example of the Data Viewer with a lot file from a 6psi boosted ZX14R. By looking at the clutch and vehicle speed you can see when he is launching, you can also see the wheel spin in 1st gear i.e. the RPM ramp up but the vehicle speed does not increase, you then see him wind back the TPS to compensate for the wheel spin etc etc.
This is obviously without Launch Control as the Launch Control would have controlled the RPM much better than what he is getting here, he would have been able to hold it open and the software would have ramped the RPM in a much more controlled manner :)
I would suggest you look at going the other way, use an output from your air shifter to signal a shift in the ECU, this will cut fuel and ignition and is fully programmable per gear based on TPS and RPM?
Cheers
-Justin.
* Last updated by: Romans on 5/1/2015 @ 8:38 AM *
