Does any body know the propulsion method of the super charger? At 22,000rpm I doubt that it is chain or belt driven.
Perhaps gears, planetary, or fluid?
2015 300 Ninja
1994 ZX9R Ninja
2008 ZX14 Ninja
1974 Triumph Trident
2006 Ducati 999R
Created on: 02/20/15 06:45 PM
redboot
Fowvay
RE: H2R Super Charger
02/21/15 4:48 AM
According to the technical data from Kawasaki on the design, "Kawasaki uses a step-up gear system in addition to a planetary gearset to drive the supercharger's impeller shaft. The step-up gear set is driven directly by the H2's crankshaft (via chain) and spins slightly higher than engine speed. The chain drive takes power from there to a planetary gear set that resides inside the supercharger's housing. This combined effect is to turn an engine speed of approximately 14,000 rpm into an impeller speed of 130,000 rpm. A planetary gear set is one way to provide a significant change in gearing within a small space."
This information is provided via Kawasaki technical publications.
