I know I was involved in a discussion about road debris falling into the engine via spark plug holes over a year ago. It would not be hard to do. The sparkplugs are down in a well and there is a rubber elctrode plug thingy called a stick coil on top. We all know how little pebbles collect in our fairings and on the motor.
So recently it was suggested that I blow my motor off with compressed air before working. I got a little compressor and have been doing a lot of blowing before after and while working. You cannot get every last grain outa the way. I think for stick coils, it is almost a given some chunkies are going to fall in the spark plug wells.
I tried greasing as I remove to trap any debris before it falls in. Works good--only prob--if anything DOES fall in, it will stick to the inside and be a lot less likely to fly out with a blast of compressed air.
tried NOT greasing but both times, I found some tiny chunks on the very tip of the stick coil which tells me something musta fell in.
Finally resorted to the blow and I am satisfied that cleared it completely. I looked down in there with my mirror tool and a flashlight. The image was much cleare than I could photo here (without using a tripod and some careful focussing) All I could see was a shiny inside and the tip of the spark plug. Kinda cool, huh?
I actually am sort of favoring the grease as you go method right now.
SO , what are your thoughts about stuff falling in the sparkplug wells. We all have to change plugs eventually.
* Last updated by: Rook on 8/4/2011 @ 9:53 PM *
