Thread: New Guy
Created on: 06/23/20 08:30 PM
GodKing
GodKing's Gravatar
New Guy
06/23/20 8:30 PM
What's up everyone,
Just bought my dream bike, a 2016 ZX14R SE (with extras).
I previously rode a stock 06 stock ZX10R and an 06 GSX-R w/ PCV and full M4 exhaust. While both bikes were so fun wnd made me smile form ear to ear ever time I turned them on, the 14 has always been my dream bike.
Currently this dream ride needs tires and after reading the comments in this forum, I’m still having a hard time deciding on a tire and size. The bike has a Roaring Toys bolt on swing arm. My intention is just to get a tire that fills the rear end out better than the stock (which looks to skinny). The 14 will serve as a daily commuter so tire that get good mileage is a must.
RE: New Guy
06/24/20 12:55 AM
I don't know anything about wide tires if that's what you're looking for. A 200/55 is about as big of a tire diameter as will fit the stock swingarm. If you have an extended swigarm, you probably can go bigger but the tires will cost more. I don't know if tire diameter effects the speedo on the Gen2.
GodKing
GodKing's Gravatar
RE: New Guy
06/24/20 7:31 AM
I was looking for a tire thats just a little wider than the stock one. I haven’t been able to find pictures of the fitment with tire sizes, which would make this a lot easier. With that said, the shops around here won’t install a tire thats not stock on the bike. They’re willing to install the tire on the rim but wont install the rim on the bike. I do my own mechanic work on my cars but I’ve never replaced a tire on a motorcycle. I might look it up and see of it’s worth the hassle, if not I’ll keep the stock tire sizes and leave that project for later.
RE: New Guy
06/24/20 10:04 AM
OK so you are using a stock width rim, this isn't one of those huge fat, rear tire bikes. A 190 or 200 is probably going to be a tiny bit fatter than a 180. As I understand it, the first number refers to the distance from the edge of the tread measured around the belly of the tire to the opposite edge--just like you used a tape measure to get the distance from the RH edge to the left. 190s and 200s are always going to be a taller tire than a 180 but they are probably going to be a few mm wider too. I'd show a pic but my briefcase is so full it takes hours for it to open with the low internet speed I have.
I have replaced tires 4 or 5 times myself. If you replace your own car tires, I imagine a bike tire would be easier. It takes me hours to do one bike tire and it is quite physically demanding. A lot of people say they can change a tire in 20 minutes with tire irons but I'd like to see what their rims look like inside. I have seen a video one member (Nightmare, I think) did where he changes a tire perfectly in just a few minutes but he must have a great deal of tire changing experience. If you do not, I would suggest paying whatever a good shop charges to change tires rather than invest in a stand, tire irons and other equipment.
As far as removing and installing a wheel, that is easy but you will need a good stand that will cost ~90-$250. I can direct you to threads about stands and wheel removal if you like. If you trust the shop enough to change tires, you probably can trust them to install your wheel. I have never brought either of my bikes to a shop but I did bring my wheels in once. I saw the guy throw the wheel on the ground right in front of me and that was the last time I ever did it. After I removed my first tire, I saw how they scraped the inside of the rim and also the outside edges. The beads were in good shape and that's what really matters. If a shop changes your tires, you can expect at least a few nicks. Then again, I marred my rims a tiny bit the first couple times I used tire irons too.
RE: New Guy
06/24/20 10:55 AM
If the shop will install the tire on the rim, just taking the wheel off and back on is pretty easy.
I'd think it's even easier on an extended swingarm.
How about contact Roaring Toyz and get their input about tires ?
GodKing
GodKing's Gravatar
RE: New Guy
06/24/20 12:03 PM
I have never been a fan of taking anything to a shop, I’ve seen some shady stuff. I have a few buddies who have referred me to some shops and they trust the shops with at least a tire change. I might have them do it the first time while i gather the tools necessary and do more research for the next one. Thanks Rook
