Far as I know, there are two modules for correcting the speedo reading for stock error or tire/sprocket mods on our bikes. Both are also used to derestrict the top speed limiter in racing applications.
First, the SpeedoHealer which is the old standby. I am told to get the SpeedoHealer V4.0 (which is the latest, I presume). That little LED readout is cool.
What does the number indicate?
Does not look like something I should install under my seat with other electronics. Would I need to have access to the buttons often?
I often hear that it is difficult to calibrate this device. Agree, disagree?
Can any SpeedoHealer be swapped over to any bike or is the module/wiring designed to work with specific bikes only (like a Power Commander is made specifically for one type of bike and will not function if swapped over to a different model)?
Next we have the Bonneville Pro which is made by Muzzys for the ZX-14. I don't know anything about it other than they claim it is much easier to use.
"How is this better than a speedohealer? With the Bonneville Pro, you don't need to change the box when you want to run top speed runs," <<<What does that mean? Change the box?
Would I need to access the buttons on the Bonneville often or would it conveniently be located out of sight under the seat?
Which do you like best or are you aware of any others speedo correction/derestriction modules?
* Last updated by: Rook on 12/18/2010 @ 12:06 PM *
