Page: 1 2 3 4 5 6 7 8 9
Thread: Hids
Created on: 07/30/09 03:24 AM
redtrace
redtrace's Gravatar
RE: Hids
10/24/09 9:08 AM
txspike, H9 or H11 in an HID application won't matter. The HIDs have no filiment and will be the same brightness. The H9 and H11 IS important for halogen bulbs because there is a different filiment in each. Also, and this should apply to both halogen and HID, the tabs on the bulb may be slightly different so that you can't install the wrong bulb in the wrong socket housing.
* Last updated by: redtrace on 10/24/2009 @ 9:09 AM *
txspike
txspike's Gravatar
RE: Hids
10/24/09 6:38 PM
Well, major problems with the HID install. According to the mechanic that came over to do the installation, the same piece - the power supply that connects to the battery - was missing from both kits. On the DDM website they have a picture that shows the wiring and how everything fits together and part C just isn't there. Here's the picture from DDM:
Now, here's the picture of one of my kits:
The piece just isn't there. So, either we're not understanding something properly here or I got incomplete kits.
Did you guys get part C in your kits? If not, what did you do?
RE: Hids
10/24/09 7:27 PM
nope nothing hooks to the battery....unless you bought part c which is the relay harness..which you dont need. you have them hooked up correct in the pics, see the blk & red wired plugs that come out oh the boot with the hid bulb? that connect to the plug the origanally plugged into the oem lights remember the lows will have to switch the wires. each unit is independant from the others so the 2 single plugs out of the ignitors hook up to the 2 single plugs coming out of the other side of the rubber boots
* Last updated by: scottjkyl on 10/24/2009 @ 7:55 PM *
RE: Hids
10/24/09 7:49 PM
txspike just sent u a pm check ur email let me know if i can be of some help to you when i did mine i did 1 at a time starting with the brights. after each 1 i hooked up i fired up the bike to make sure they worked before mounting the ballasts and ignitors i have pics of where i mounted mine in this thread seemed to work out ok for me but ive seen half a doz ways they were mounted on here so its just a personal preference i guess
* Last updated by: scottjkyl on 10/24/2009 @ 8:03 PM *
txspike
txspike's Gravatar
RE: Hids
10/24/09 10:10 PM
Thanks for the tips Scott. Hey, I'm not seeing any PM's. Even sent myself one and nothing pops up on here saying I have a message and can't find any links to click on to see PMs ?!? So, if you sent me something on PM, I didn't get it. You can email me at intrepid.dust@gmail.com
Anyway, I'm going to tell that guy what you said about plugging into the original OEM socket for the lights. Hopefully he can get back over here and we can get it fixed. Right now though the bike's been put back together. He was convinced that not everything was there so he reassembled everything.
RE: Hids
10/25/09 4:54 AM
pm's go to ur email address u have set up in here check ur junk email
RE: Hids
10/25/09 4:58 AM
you only need to remove the ram air covers and the wind screen to do this job. you could do this job yourself it really simple to do
* Last updated by: scottjkyl on 10/25/2009 @ 4:59 AM *
RE: Hids
10/25/09 6:13 AM
T i was just thinking that may be the way to tell your bulbs apart the highs will plug in correct with factory harness unless its the factory harness on the lows that is back wards
* Last updated by: scottjkyl on 10/25/2009 @ 6:14 AM *
RE: Hids
10/27/09 5:53 AM
T you get those hids hooked up?
txspike
txspike's Gravatar
RE: Hids
10/27/09 7:38 AM
Unfortunately, no. The guy that was working on it hasn't gotten back in touch with me. I've already paid him for the time he spent working on it on Saturday. When he told me that without that piece it couldn't be installed, I didn't figure it would be fair for me not to pay him since he did spend the time taking it apart. Now, as it turns out, he just didn't know how to get the job done, and I'm out the money I've already spent. I'm still giving him the benefit of the doubt and assume that he'll do the right thing but. But, as it stands right now, I've got close to $200 worth of HID just sitting there uninstalled and another $60 of meaningless disassembly/reassembly fees...
RE: Hids
10/27/09 10:04 AM
ouch well if you want to attempt it i can walk you thru it for free lol really not that hard let me know like i said only got to take off 3 peices of plastic $60 for that sounds steep
redtrace
redtrace's Gravatar
RE: Hids
10/27/09 4:36 PM
txspike, you have everything you need for the install. Take the plug off of your stock bulb and plug it into the 2 wire connector coming from the ballast. Now, take the 2 wires coming from the smaller box with your kit and plug that into your new HID bulb. Clip that rubber bushing thing off of the HID bulb wires and also the short wire with the other end of the 2 wire connector.
RE: Hids
10/28/09 1:17 AM
Hey TXSPIKE-HERE YA GO- -also,see that plug saying "to Factory connector"?-that's the one that gives people trouble sometimes.You can take that plastic plug off,keep the leads on the end of the wires-and insert directly into the factory BLUE or GREEN connector(whichever you're installing)and then SILICONE the connector with leads in it after making sure she's coming on each time you fire them up.YOU DO NOT CUT ANY WIRES OFF!!!!Also,you MAY have a problem with turning the bulb socket itself into the metal lens socket.If so,just snip off a tiny bit of the LONG tab on the bulb ears.I know ONE SET of the lens metal sockets are designed slightly differently for the STOCK H9,or H11 bulb(as mentioned above)so they don't get mixed up for high or low bulbs installation.But all the tabs on the DDM's are THE SAME DESIGN.Meaning it will turn and fit for ONE set of lens sockets,but NOT the other.I used ALL 55w H11 bulbs on mine.6,000K.............not sure what Redtrace was talking about with "cutting the short wire off"-My wires all fit into something-there wasn't any "short wire" that I recall?
* Last updated by: blue07 on 10/28/2009 @ 1:35 AM *
RE: Hids
10/28/09 5:00 AM
blue i think red was talking bout cutting off the boot and removing that ext wire. which is ok if your mounting close enough to plug directly into the ballast. i guess you just need to decide where you will be mounting the ballasts and how much wire you will need before removing that peice of harness imo
RE: Hids
10/28/09 12:39 PM
Well-yeah,I can see if ya don't need that long extension coming out there-I did.But why would you cut it?It disconnects right there nice and tidy like.Yeah-you're right about that.Didn't think of NOT using that extension.
* Last updated by: blue07 on 10/28/2009 @ 12:41 PM *
redtrace
redtrace's Gravatar
RE: Hids
10/28/09 3:21 PM
blue, scott is correct. I meant to remove the extension wire. I did not need it as I mounted mine to the turn signal bracket on each side. The low beam wire is long enough to reach with no problem.
RE: Hids
10/28/09 4:12 PM
Yes-sorry Red-I forgot that extension was on there-I ran mine back along the ram tubes.
txspike
txspike's Gravatar
RE: Hids
11/04/09 7:39 PM
First of all, I would like to thank everyone for their help.
I am happy to report that I was FINALLY able to get my HID's installed and working this evening by a guy here in the area. Everybody's advice was spot-on and the key to getting everything working properly was to reverse the polarity on every bulb (both hi beams and low beams).
And damn, these things are BRIGHT! But having them made me realize that I really do need the LED's that someone earlier in the thread suggested. Next to the HID, the stock running lights look really yellow and pale....
RE: Hids
11/04/09 8:46 PM
i used blue running lights glad you got them installed
extrapilot
extrapilot's Gravatar
RE: Hids
11/05/09 4:37 AM
Heed my word about the running lights. They are NOT #194 bulbs in there. Take them out of the holder and you will find the correct number printed on the base of the bulb. They are a newer part number that Kawasaki is using. You will have to hunt around on the internet to find them. Also, the directionals are a different type as well, not the normal 1156 or 1157 type that used to be used for years.
You can use the 194's but you have to enlarge the socket, and run the risk of cracking the socket holder.
If you crack the socket holder, it's not such a big deal because they detach from the hardness.
RE: Hids
11/05/09 5:08 AM
i dunno bout that i got 194's they fit in and were the same as the oem maybe 08 model is diferent...i dunno
extrapilot
RE: Hids
11/05/09 7:50 AM
I think that they maybe close in size but the ones I used are PN WLED-NWLX from http://www.superbrightleds.com/.
Also, I did find the correct part number on the web to the OEM ones that were in my bike, but superbrightleds didn't offer that number. I can't recall the actual part number, but they are printed on the base of the bulb.
* Last updated by: extrapilot on 11/5/2009 @ 7:53 AM *
RE: Hids
11/05/09 1:37 PM
looked at my oem bulbs and did not find any markings on them and wouldnt u know the manual says nothing about replacement bulbs
Sambeaux
Sambeaux's Gravatar
RE: Hids
11/09/09 3:58 PM
I just installed my HID's. Two 55W kits from DDM tuning, with no headlamp adjustment. I cant honestly say I'm not that impressed, everyone else seems to be blown away and I'm like WTF!?! I do understand about the headlamp position on the low beams but the hi beams are on point, I am on the verge of declaring this mod a not worth the money.
RE: Hids
11/09/09 4:10 PM
Sorry to hear that Sam-what K factor did you get?I've got the 6,000K,55w bulbs in all four lamps-these things are WAY bright...So much so that during the daytime I get flashed sometimes by oncoming cars-and I've got mine set just about right for NOT blinding anyone coming at me.Mine are BRIGHT WHITE hues.There's NO comparo to the stock bulbs with mine.
* Last updated by: blue07 on 11/9/2009 @ 4:11 PM *
